New Items Driveline Cushion Bushings And Decals
Driveshaft Rubber Cushion Bushings Now Available For 25.00 Per Pair. Also New Adhesive Yellow Lube And Specification Decals At 3.00 Ea Or Two For 5 Dollars, Specify Stepdown Or Pre Stepdown, I Will Pay The Postage, Bill Albrights Vintage Coach, 16593 Arrow Bl. Fontana, Ca. 92335
I think these items are available from K-Gap? Why not supply some item that no other company makes? Just a thought.0
I think its probably good that we have multiple sources for repro parts. Our population isn't getting any younger and we've seen a few items that used to be made no longer available after the person's retired or passed on. Not to many people want to get involved with the time, expense and trouble of making some of these parts.
Also, are there any differences between the parts? In the past some have been exact replacements while others, although they would work, differed from the original part- either in the way it looked and/or its servicibility (sometimes better than the originals).
Any differences in these bushings?0 -
Hopefully Bill reproduced several hundreds of these bushings. In order to use up the ones he doesn't sell, he will have to continue restoring Hudsons until he uses them up.:):)0
Also need the lube & spec decals for the Jets.0
the center cushions have a one/eigth shorter stud but work fine, bill a.0
