1946 Hudson Brake Drums
Jim Kilday
I need to replace the front brake drums in my '46 Coupe. Is there a new manufactured drum that will substitute?
Jim Kilday
Jim Kilday
hi jim, none that i have ever heard of. might have some good used ones. be sure to measure your diametr. commodore and super were different size.0
You Are Right Rick, I Shouldd Of Been More Specific And Said Commodore 8 Vs Super Series, Bill Albright0
I have some new old stock drums here part number 166295, but would be expensive to ship I would imagine.I'm In Australia. Would you like a holiday, come pick them up, take them back as cabin luggage.0
Thanks for all the help. I was able to get a pair from Glen Johnson in Brigham, UT.
Jim Kilday0 -
i was wondering about that part #166295 what size drum would it be for i am looking for some drums that will fit my 46 pickup it got 15 inch tires and wheels - g0
The pickups should have 11 x 1.75 inch brakes same as the Commadore 8. You can substitute stepdown 11x 2 1/4 if you change the backing plate, swap the bearings around and use a double washer behind the nut.0
thank you for the info uncle josh - g0
- 611 Vehicles
