Need Upper and lower Rocker Moldings For 52 Hornet Coupe
Hi,
Looking to buy upper and lower rocker moldings for 52 stepdown (both sides).
Please PM me or e-mail me at hetnptelcel@aol.com (drop the het).
Question: Are the left and right sides interchangeable?
Neils-
Sort of. Keep in mind that while you can switch them, if you are buying used pieces that spent a lifetime on a car, the underside or side facing the asphalt will have a decidely heavier "road rash". If said piece were switched over, the previous "bad" side would now be up. I've seen many pieces where the rash is so deep, that sanding them all the way out before polishing would leave the stainless, which is fairly thin anyway, too thin to be useful.0 -
Thanks Russell, makes sense. I've been offered a set but both sets are for the left. I'd rather find both sides if someone has them.0
