important measurement
Hi all in Hudsonland I need to know the measurement of the rod that has what apeares to have little tierod ends on each end that hook to the bell
crank that stick out of back corner of engine on drivers side to shaft that moves rods for twinhcarbs the bellcrank also has rod for gas pedal and shift down linkage. I need to know the length of this rod with the tietod ends from center to center of threaded ends thanks duncan
I measure it at 5 1/4".0
Hi Park Thanks for your help and every body else . duncan:D0
