Anybody have carbs?
RL Chilton
Administrator, Member
I'm looking for a carburetor, still need one more. WA-1, model 968. It's for a Twin-H set-up.
Russell,
You may want to try Walt Mordetti? Niels0 -
Niels-
That's kinda funny, but you wouldn't know why. I've sent Walt 3 carbs to re-build for me and we ended up with one "correct" one (the other two didn't have the tags on them and had to be miked). Walt's got one done and we need another for the Twin-H.0 -
Russell,
I have one that I bought a while ago that I thought I might need. I may be persuaded to sell it if it is what you need. The brass tag on it says 776S. I'm not a carb expert so not sure what model it is. My carb says Carter WGD and there is also 118-68 on it. Not sure what model it is.0 -
The # on the tag denotes what model it is. I'm not familiar with all the #'s. Apparently, all WA-1's are not the same. Some were for Twin-H, some for PM's, some for Wasps, some for single carbs, some for dbls. Walt knows all that info by heart . . . I have to go look it up. Thanks for the offer, but neither one of the carbs you mentioned is the one I need. I found one a little earlier though and will be on it's way in a couple of days.0
nhp1127 wrote:
That 776 is for a 2 barrel set up. Can be used on 6's and 8's 48 to 50, 262 or 254 engines. Walt.Russell,
- 611 Vehicles
