Low Beams
On High Beams, All My Lights Work. On Low Beams Just My Tail Lights Work. I Have Mounted On The Dash A Glass For Seeing Traffic Lights. It Had Come Loose And I Was Working Under Dash To Tighten It, But I Can Not See Any Loose Wires. I Dont Know If I Desturbed Something, Or It Was Just Its Time To Quit Working. The Wiring Is All Origanal. Oh, It Is A 53 Hornet.
The power for your headlights go directly to the dimmer switch. The dimmer selcts one or the other filaments in the bulbs. Most likely, a bullet connector has come apart at the dimmer switch. next would be a defective dimmer switch. If you have a test lamp or a voltmeter, you can check the switch. If you don't, then try reversing the high/low beam wires at the dimmer switch . If the switch is defective, the high beams will not work, and the low beams will.0
