Looking for Twin- H Aircleaner Support Bracket
Hi,
Does anyone have a support bracket for a 308 Twin-H aircleaner? My aircleaners are the non-oil bath type so I don't know if the oil bath type brackets would work (but I would bet they will). For clarification, one end of the support bracket bolts directly to the bottom of the aircleaner and the other end to a head bolt. I just need one as the car already has the front one. Thanks!
That is a "Z" shapped piece of strap steel. Very easy to duplicate if you have vice, drill and a hammer. The head end is a hole large enough to pass the head bolt. The air cleaner end is slotted just like the piece that is on your linkage for the front A/C Hope this helps.0
Dave's right, it's a very simple piece to make. But, if you don't have the tools, then e-mail me.0
I'll make it for you when I come up to work on the Commodore.0
You da man!0
