54 Hornet TV Lever
Hwllo in Hudsonland we hope everyone had a safe Christmas.
Our Hornet came from the factory with ma single 2 barrel carb
and dual range Hydramatic trans. Now i am changing from single 2 bbl carb to twin H and hydra trans. I had to find the correct bellcrank. Now i am sure i have to find the matching tv lever on tranny. The correct no. is 8614822. Trans no. H54 8007
SN of car 7286903 Thanks duncan
duncan wrote:Hwllo in Hudsonland we hope everyone had a safe Christmas.
I changed a 52 Hornet to twin h and borried the bell crank from a 52 twin h car for a pattern. Welded a piece of 1/8 x 1 on the single bell crank drilled the hole to match. Cleaned it up painted black and installed it works perfect.0 -
I will have to look thru my parts bins, if I have one I'll let you know. Lou Cote PS. , don't know where you are located, someone may be closer.0
Thanks Lou For your help I live in Westlock Alberta Canada
Mail it . duncan0
- 117 Hudson 1916 - 1929
- 98 Essex Super 6
