Ex. manifold
Hi - I have a good (no cracks) step down 6 cyl. ex. manifold which in the past I removed the heat control valve. At the time I had it on a eng. with a Edmonds in. manifold with a plate blocking off where the stock in. manifold bolts on. My question is will the the manifold work OK (without the heat control valve) on a stock 308 Twin H set up? It will be used in S. Cal. - no real cold conditions. Thanks for any help or opinions. Norm:rolleyes:
Norm, it should work fine, particularly in your mild climate. Just have to plug the riser valve shaft holes, which I figure you've already done.0
