212 exhaust
I'm going to get my exhaust manifold split on my '37 212 engine. Plans are to run a set of dual exhausts with Smithy mufflers. Looking at the manifold on the engine, it appears very easy to remove it, plus all of the fasteners are readily accessible.
Question I have is - Does the manifold have a gasket between the manifold and the block? If it does, who carries a replacement, if one becomes necessary? I'd really hate to pull it off and discover that I need a gasket and one can not be had!
It looks like it does. You can buy the gaskets from these people.
Dale Cooper
http://www.hudsonmotorcarco.com/
Randy Maas
http://www.21stcenturyhudson.net/0 -
Ken U-Tx wrote:
Ken, still waiting for an answer to the parts you told me about. Walt Mordenti.In all my years of fooling with vintage engines, the only cars I have seen with no manifold gaskets were Nashes and some English OHV Ford 4 & 6 cylinders that used a header tube clamped to the cylinder head, or in the case of the Nash flathead 6 , the side of the block. Those things were notorious for the tubes starting to leak after a few years of expansion and contraction, followed by the owners/ mechanics over tightening the clamp bolts which only crushed the tube to make it leak even more. I remember my '50 Nash Ambassador at highway speeds sounded like an old Hoover vacuum with a flatulence problem. When not leaking they had a distinctive moaning sound, kinda like OOOOOOOOOM, OOOOOOOOO, OOOOOOOOOOOM! Kenneth (not as deaf as it may seem when hearing aids are on and working right).0 -
Hey Patrick,
I was also contemplating a split manifold for my 36T. My question is can it be done so as not to heat up the side mounted distributor? I found gaskets in two places: egay of course, and I have a local gasket guy out here called Olsons gaskets. He has EVERYTHING and what he doesnt have he can make.
Let me know how it comes out.
T Jeff0
