35 Terraplane cutout relay
35 Terraplane
Does anyone have a source for the charging circuit "cutout relay" or "circuit breaker" for a 1935 Terraplane Special. I found a copy of the original owner's manual which shows a charging circuit marked "without regulator". The diagram shows a circuit breaker. This is the part I need.
I don't know where you get a cutout relay for a Terraplane. But I believe that one from a Ford Model A would work since all it does is open the points if the current reverses though the cutout relay. That is the battery tries to charge the generator.
http://www.snydersantiqueauto.com/50300 -
call Sammy at northwestern auto supply in grand rapids, mi. their website also has a part search form. sammy is a great guy. my cut out on my '35 is an auto lite, but i do not see a part #. regards, tp0
Pro Antique Auto Parts in CT has them. (860) 623-8274 or http://www.proantiqueauto.com/.0
TP, When your car is running does the tell-tale light on the dash remain lighted?
Tom0 -
tjfxmk, it you're running the simple cutout relay, you can connect that tele-light wire to the terminal on the cutout where the generator output wire goes, and the light will work OK.0
