212 engine heater valve
I need a good heater valve that screws into head on a 212 engine. Mine will not stop seeping, the seat inside has corrosion. The one I have is a 90 degree brass fitting with a hose barb on the end and a wing nut on a shaft that screws up and down to open or close off the water to the heater.
Scott
Scott
Scott wrote:I need a good heater valve that screws into head on a 212 engine. Mine will not stop seeping, the seat inside has corrosion. The one I have is a 90 degree brass fitting with a hose barb on the end and a wing nut on a shaft that screws up and down to open or close off the water to the heater.
Scott
I'm useing the ball type that has a flip HANDLE from the hardware store, have had the same problem with the screw in/out type. You can also get a cable operated one at about any auto parts. BUD0
