Electric hand removal
The rounded left-hand end piece is threaded on. Isn't there a pair of slightly indented flat spots on that piece, so you can put a large wrench on it? If not, try a common rubber kitchen gadget for getting jar lids off. Inside that end piece there's a nut that holds the main housing to the steering column.0
Park W wrote:
You're also gonna find a whole mess of wires that you will want to mark/identify where they go on the plug {mark this also}at the bottom of the column so you can pull them out and get them back where they belong. BUDThe rounded left-hand end piece is threaded on. Isn't there a pair of slightly indented flat spots on that piece, so you can put a large wrench on it? If not, try a common rubber kitchen gadget for getting jar lids off. Inside that end piece there's a nut that holds the main housing to the steering column.0 -
For more info on the Electric Hand check out Gregg Maroney's site @:
http://www.hudsonterraplane.com/tech/tech_index.htm
I put together, from several sources - mostly Hudson, a technical handbook on the 1935-1938 Electric Hand.
It's in the 1935 group under 1935-1938 Electric Hand Transmission Control.
Alex Burr
HudsonTech
Memphis, TN0 -
Thank you for the info guys. The electric hand will not be functional on my car, all of the transmision parts were gone when I got the carl, but I am planing on cleaning it up and having it in the car for show.0
Chris Penny wrote:The electric hand will not be functional on my car.
Hey, Chris, where's your sense of adventure! LOL. Here's a photo I couldn't find earlier.0
