stepdown front brake hose part numbers
My list has EIS SP-1418 as an alternate
Let us know if it works0 -
What does EIS stand for? I spit this at a couple of them and they did not understand what it was. (neither did I)0
walt norem wrote:
Just call Norm Blackmer in the CIC chapter as he has all brake parts, (909)-984-5544. Tell him Walt sent you.Does any one have a current # for these? The Napa # 10303 is no longer any good. It is now a rad. hose.0 -
Back in the late 70's I had a '49 Hudson that I finally got running. Friend of mine came around and we decided to take it for a drive down to the end of hte street and back.
Trouble was the right front brake hose had a hole in it. So, having a '68 Ford Ranch Wagon, with a rusted out frame so it wasn't going anywhere except to the scrap yard, I took the right front brake hose off that and found that it fit the Hudson, no problem.
We got it to the end of the street and back - back being the operative word here!!!
Just a suggestion - should be ford parts all over the place.
Alex Burr
Memphis, TN0 -
Wagner # F 24070 - Norm0
herm wrote:Wagner # F 24070 - Norm
Advance Auto Parts # H19015 Tru Torque. Listed in Catalogue, not in computer system yet. Advance also has some wheel cylinders etc, front wheel bearings, front wheel seals. ignition parts, etc. Just need to have someone go to the cataloges if not in the computer. They are just getting around to have some stuff in the system. I work for Advance so I have researched Hudson parts.
Jim Spencer0
