Speedometer Gears Info Needed
Has anyone ever tried putting in different DRIVE AND DRIVEN gears to correct a speedometer when putting a late model rear end in a 30's car ? Putting a 3:07 in my 37 Terraplane. Drive and driven gears are such that a given drive gear will operate several driven gears. The 37 DRIVE gear is .985 I.D. X 1.940 O.D. X .750 wide , no inner splines and held secure by just the tension against it. If anyone has a DRIVE gear and or driven gear they would part with from a car that had a 3:07 rear or close to it I'd like to give it a try. I think the O.D. would be the only critical factor, width and I.D. could be built up/machined down to size. Thanks, BUD
Since 3.07 was not a factory option in '37, there might not BE any gears available for that praticular transmission. This wouldn't preclude you from making them (with a the help of a good machinist), I'd think. I've also heard of universal gear reductions that can be attached to the transmission and adjusted to fit the ratio, but have never checked them out.0
Jon B wrote:Since 3.07 was not a factory option in '37, there might not BE any gears available for that praticular transmission. This wouldn't preclude you from making them (with a the help of a good machinist), I'd think. I've also heard of universal gear reductions that can be attached to the transmission and adjusted to fit the ratio, but have never checked them out.0
37 Terraplane#2 wrote:Has anyone ever tried putting in different DRIVE AND DRIVEN gears to correct a speedometer when putting a late model rear end in a 30's car ? Putting a 3:07 in my 37 Terraplane. Drive and driven gears are such that a given drive gear will operate several driven gears. The 37 DRIVE gear is .985 I.D. X 1.940 O.D. X .750 wide , no inner splines and held secure by just the tension against it. If anyone has a DRIVE gear and or driven gear they would part with from a car that had a 3:07 rear or close to it I'd like to give it a try. I think the O.D. would be the only critical factor, width and I.D. could be built up/machined down to size. Thanks, BUD0
- 174 The Flathead Forum
- 601 Vehicles
