clutch and brake pedals controls
trying to hook up brake and clutch control mechanics and do not have a schematic showing all the parts, does anyone have one that could be e mailed? parts book shows for jet only. mine is a 5C. it appears to be missing a bushing in the side of the bell housing clutch pedal shaft goes tothanks steve
Here is a schematic of the pedal assembly for stepdowns.0
J2-18 is a rubber sleeve that cushions and connects the clutch linkage to the linkage mounted to the bell housing. In the past I have reinforced rubber hose cut to fit to make this bushing.
Good luck0 -
This thread sounds vaguely familiar . . .:rolleyes:0
There is bushings in the bell housing that J2-15 goes in. They were worn bad in my 47 PU.0
- 612 Vehicles
