wheels stud bolt size???? help!
I guess I get to answer my own question.........anyway, they are 1/2" x 20 and either 3/4 or 1" long....0
The threaded portion is 7/8"0
Smasher-
Strictly out of curiosity, why the switch? The lug bolts work better and are stronger to boot (less parts). Are you gaining something by pressing in studs?0 -
RL Chilton wrote:Smasher-
Hey Russel!....good to hear from you. I'm not pressing in any studs...it just sounds like it i guess!.....I have a set of old cragar ss mags with brand new tires I've had put up a while and out of curiousity wanted to see what they looked like on it. I found out quick the bolts were too short to mount the thicker cragar's so off I went with lug bolt in hand and had COMPLETE HELL trying to find some a half inch longer!.....man, it was unreal!......finally found some at advance auto parts. I went to two different bolt companies and said they couldn't get them so I went to home depot, tractor supply, napa, and several others before finding a rack of 1/2" x 20 x 1 1/2" lug bolts!...and they fit perfect!......but no I'm definately not going through the trouble of pressing in studs!......(not that determined yet!)......0 -
oh shoot.......I thought I had it in there! whoops!........I found a few at advance auto parts believe it or not........the rest, being I needed 20 of them were found at an industrial bolt outlet called a&l bolt and screw here in Lake charles LA.So... Where & who did you end up getting them from?
...Oh wait......I did have in the first post "finally found some at Advance Auto Parts"..........you just overlooked it!0
- 115 Hudson 1916 - 1929
