need intake valves
I need 2 useable 1937 212 intake valves in a hurry. 3/8 dia stem , the later ones are bigger . HolmesViolins@Insightbb.com
Dale Cooper in Cincinatti should have them. (513) 821-6200. But measure yours again ... 3/16" sounds too small.0
37 Terraplane#2 wrote:I need 2 useable 1937 212 intake valves in a hurry. 3/16 dia stem , the later ones are bigger . HolmesViolins@Insightbb.com
'36 and '37 valves had 3/8" stems. Later models were reduced to 11/32"0 -
Park W wrote:Dale Cooper in Cincinatti should have them. (513) 821-6200. But measure yours again ... 3/16" sounds too small.
Yeah the ole dummy punched in the wrong thing when he knew they are 3/8 , anyway you guys know what I need for a 37 , guy doing work on my engine wants to get it done NOW so I would use used ones in good shape if I have to , got 2 that have been ground too many times.---BUD0 -
New ones from Dale Cooper will be there no more than 2 days after you order them by phone. Why go with used ones?0
