48 Venetian blinds
I am looking for the instruction sheet for installing rear window blinds in a 48.In the original kit came an intallation sheet with needed info that I would like to read before drilling the mounting holes. If anyone has this info. can you post the sheet or post the spacing of the mounting hardware and what blind # is on top to start eg 215540? Thanks
41truck wrote:I am looking for the instruction sheet for installing rear window blinds in a 48.In the original kit came an intallation sheet with needed info that I would like to read before drilling the mounting holes. If anyone has this info. can you post the sheet or post the spacing of the mounting hardware and what blind # is on top to start eg 215540? Thanks
The instruction pictures on my site are incomplete
and may not be of help... but they can be viewed at this URL
http://hudsonrestoration1948-54.com/PDFFiles/HudsonVenitian%20Blinds.pdf0 -
Ken
I was checking that site out before but could not read the sheet as the print was too small.Do you know anyone that has a copy of that installation sheet?0 -
Sorry... I do not.0
If someone has these in their car can you post the spacing between the supports so I can drill the holes for mounting them? Thanks0
The measurement on my 50 Pacemaker Brougham (small window)
is 19 1/2 inches center to center. Don't know if it's per the instructions or "correct" though.
John0
- 612 Vehicles
