Speedo Gear Needed
Larger tires make car run faster than indicated. For what transmission do you need gear for? Earlier ones have longer shaft, steel left helicore gear and later has shorter shaft with right helicore fiber gear.
Check with Speedometer Service Company
5801 W Villard Ave, Milwaukee, WI 53218 (414) 463-6660
Fax (414) 463-6661
info@speedometersolutions.com0
