Engine Temp Sender
Original sending unit will work fine. I have used same one on our 51 for over 15 years with negative ground 12 volts.0
Well...I also do not have the original. Is it still available someplace?0
sorry, I didn't notice you wanted one to fit small block chevy. I'm not sure of thread, but if it is 1/4" pipe thread, you can try Echlin TS-6464 or TS6164 or Wells TU-1 for all AMC 6 1956/57, all chrysler 8 56/56 and all Hornet V8 1956/570
Thanks! I'll bounce those numbers off some parts counter guys and seee if I can find one.0
- 111 Hudson 1916 - 1929
