Keep burning out condensers....
Unknown
Howdy,
I have an issue with my Stock 48 Commodore 6. Within the last few months, it has died on me twice and I could not get it restarted. After a fellow Hudsonite checked out some things, he determined it was the condenser. After replacing it, it started right up. It just died again on me yesterday, I replaced the condenser again, and it started right up.... any ideas as to what the problem maybe? Niels
  • Park_W
    Park_W Senior Contributor
    Niels, if the car has a stock coil and not some special whiz-bang thing, try condensers from a different source and see if that changes your luck.
  • In my youth the Blue Streak brand had a common fault like you describe. Use a Delco condensor and be sure the ground lead from the distributer body to the plate is electrically solid and clean. Also clean and lightly gouge the plate under the condensor mounting bracket.
    Everything said by the others is correct, too.
  • nhp1127 wrote:
    Howdy,
    Do it Walt's way. Put the condenser on the outside of the distributor housing and connected to the outside post where the ignition wire goes. Now you have a good ground and will stay cooler. Just make sure you have a ground wire housing to plate to help points ground.
  • thanks for all the replies and all this makes sense. I think I'm going to simply put on a Pertronix electronic ignition and not have ignition problems again....
    Walt,
    Do you happen to have a part number for the externally mounted condensor you use?
  • RL Chilton
    That will definately solve your problem.
  • JasonNC
    JasonNC Expert Adviser
    When you find out which Petronix unit fits the 262, how about posting the #. BTW, have you converted to 12 volts negative ground?
    JasonNC
  • RL Chilton
    Russ Maas (21st Century Hudson) sells the Pertronix unit, or you can send in your unit and have them do it for you.
  • DaveFury wrote:
    Walt,
    Just use the bracket that comes with the condenser. Attach it to the screw that holes one of the cap clips. Nothing else is needed. When I do this for owners, I make a small aluminum plate, bolt to cap clip and screw condenser to it. Walt.
  • 464Saloon
    464Saloon Senior Contributor
    JasonNC
    Part# is 1362P6 if you are 6v. 1362 if you are 12. I have two sitting on my desk here as I am going to convert both Neils 48 and 52. I did his 51 which is 12v and did my 54 when I converted to 12v three years ago. Neither car has ever had a problem. I have also done my 68 442 and 55 F-100 and they also work great.
  • JasonNC
    Rob,
    Do you recommend getting the 40,000 volt coil? How complicated is the installation for a novice?
    Thanks,
    Jason
    Thanks Walt. I will do just as you said.
