'47 Pickup Gas Tank Parts Needed
Hello,
I had the gas tank for my 1947 Cab Pickup refurbished by Gas Tank Renu, and am to the point where I want to install it. However, I need the sending unit and the pickup unit for the tank.
The incorrect tank I removed from the truck had the sending unit and pickup tube combined as one unit. If I am seeing the illustration in the Mechanical Procedure Manual correctly, the 1947 tank uses two separate units.
Can anyone point me in the direction of the parts I need? Going by the manual, they would be the Gasoline Tank Strainer, Gasoline Suction Pipe, and Gasoline Tank Gauge Unit.
Thank you in advance, and take care,
Steve Bryson
Steve Bryson
Contact Paul Schuster in PA. PAULLARGETYPE here on the forum. He carries new reproduction sending units, and if I remember right, has correct ones for 47? . . . not positive, but I think he does.0
Yes i have the correct one you need i'll send you a message0
