dash on 53 super wasp
am about to reassemble my dash. will be installing new vinyl and am trying to find name of the cloth stainless bead that is 54 " in length that goes between the front of dash and the vinyl.. would like to nname for this and perhaps a supplier
steve
steve
As far as I know, there isn't a supplier for this. Check with your local upholsterer and see if they have something. Several Hudnuts I know of still need this piece.
Also, check Restoration Specialties (google them on-line) and see if they have something that will work. If you find a good source, please share with the rest of us.0 -
The following company provides fender welt with a stainless bead. They sell on ebay and have a website:
Dennis Carpenter Ford and Cushman Restorations Contact Information
Carpenter Industries, Inc
4140 Concord Parkway South
Concord, NC 28027
phone 704-786-8139
fax 704-786-8180
http://www.dennis-carpenter.com/
:cool:0 -
Just for your information, I emailed Dennis Carpenter requesting stainless steel bead rerquired for dash and received below message.
"We do not have the parts you need
You may want to try www.restorationspecialties.com"
I may installed item I picked up from a upholstery supply store that looks similar to stainless steel bead, but not same durabilty; it's clear plastic pipping offered in gold or silver with insert of almost same width of original Hudson installled.
Please advise, if you would like pictures.
Ray0 -
ray would like some pictures
i went through the dennis carpenter on line catolog's and found in the 32 to 47 car catolog the following
48-16070 ss bead fender welt looks like the same stuff have not contacted them yet. its on page 78 of there catollog comes in 8' lenghts
do u have there e mail address
thanks steve0 -
bartibog1 wrote:ray would like some pictures
thanks steve
Below is address I emailed and eceived immediate quoted answer, if they offer I buy and use instead the what I presently have, please let me know if you have any luck?
info@dennis-carpenter.com <info@dennis-carpenter.com>0 -
received reply from dennis carpender they have 4816070 ss in stock
steve0 -
bartibog1 wrote:received reply from dennis carpender they have 4816070 ss in stock
steve
Hi Steve does it look like or similar to Hudson stainless steel bead?
Ray0 -
The stainless steel beading from Dennis Carpenter is a fender welting and has a very thick bead. It is what is used for the 41 thru 47 rear fenders on Commadore models. You cannot use this on your dash as it's about 100 times larger that what you need. The dash welting has been thourghly researched and there is currently nothing comparable to it. If yours is not good, I would simply leave it out.
Allan0 -
Aren't the stainless beads attached to window felts used in car windows the same size used on the Hudson dashes????0
WildWasp wrote:Aren't the stainless beads attached to window felts used in car windows the same size used on the Hudson dashes????
Wildwasp-
Yes, it is very near the correct diameter and was planning on looking into this possibility when the time comes.
Ray-
Please e-mail me a pic, as I'm yet to solve this particular dilemma for the 'vert. and like I said in an earlier post, have several Hudnuts who are also looking that I know of.0 -
Reference bead picture offered in gold & silver, almost finished with my Buick and will start to complete next week. I am just waiting for delivery of American Racing Wheels and install new set of tires, install hood and button up required balance of restoration...I have restored white ssteeing wheel that I'll be using, not pink one in picture. Yesterday I had VIN # inspected and finally received rergistration & plates...
Reference dash/bead from my upholstery shop, my concern for almost identical look of stainless is item pipping/bead is made from vinyl and in Vegas hot sun, may discolor in time; I can always use sun shades or dash cover, but would prefer to find proper stainless steel?
Ray0 -
RL Chilton wrote:Wildwasp-
Ray-
Russ, if you want next week when I visit upholstery shop I'll pick you up gold, silver or both and mail to you; send me your correct mailing address. Also if you want or need I have HudsonFel-Pro TS 4482 A transmission set, replacing # 165613 for Hudson 6 & 8, 1941-53, National Oil Seal #7037 and Chicago Rawhide # 25950 which I puchased some time ago thinking I was going to restore Hudson; your for the asking...
Ray0 -
Thanks, Ray. Sent you a PM.0
