Wanted
Does anyone know where I can purchase a spare tire tub for a 41 husdon four door? Was able to order a floor pan and front pans for it but no tub. Something even close would help. I don't know how deep it should be because the bottom half is completly gone. Thanks
Where did you find the floor pans for your '41?
Maybe you could find a tub from a donor car (not necessarily a Hudson) that could work with a little fabrication...
or
You might be able to fabricate one using trailer replacement fenders --- invert, weld some sides on it and cut to fit. Tractor Supply Company sells a couple of different sizes...
Craig0 -
I ordered them at Classic 2 Current Fabrication LLC.0
How about an English Wheel, some flat steel a torch, hammer and a little time. I did my inner fender wells that way on my custom Hudson. Not that tough.0
This spare tire tub for a Chevy might work.
http://www.chevsofthe40s.com/detail/12344/Chevrolet_WHEEL_WELL_SPARE_TIRE_DIE_STAMPED.html
Check out Classic 2 Current Fabrication's Hudson parts.
http://www.c2cfabrication.com/store/index.php?manufacturers_id=120 -
I just measured my '40 four door tire well. Inside floor opening 30 3/4 long, 9 wide, 8 1/4 deep. This was with the help of my three year old so the numbers may be a little off. She decided that the Hudson is her car and anything I do with it she has to help.0
Super 7 wrote:I just measured my '40 four door tire well. Inside floor opening 30 3/4 long, 9 wide, 8 1/4 deep. This was with the help of my three year old so the numbers may be a little off. She decided that the Hudson is her car and anything I do with it she has to help.
Do your best to encourage that!0 -
mars55 wrote:This spare tire tub for a Chevy might work.
Thanks for the c2cfab link!!! Looks like they have some good stuff.
Craig0 -
Thanks guys for the feedback. Going off of Super 7 measurements and Mars 55 suggestion of the chevy wheel tub. I'll probably go with with the tub as its pretty close to the hudson. This should complete my search for the panels I need. This is one heck of a forum! JIm0
That's awesome, Jim. glad it worked out. Please post some pics to show your progress.0
- 612 Vehicles
