need a clifford 4bbl intake and a chevy HEI for a 308
Hi,I'm making progress on the '51 super 6 brougham with a copy of the 7x and a chevy 700r4 behind it.I need a Clifford 4 barrel intake manifold and I have heard somebody is modifying the Chevrolet HEI distributor for use in a Hudson,Can anyone help?,thanks,Dave
Dave, Why not use the Hudson Aluminum 2-barrel manfold as found on the 48-49 big 6
and make an adaptor for the G.M. T.B.I. (i will be making this set-up soon )
As for the 700-R kit that you have for the 308,could you post some pics. of it for all to see.
I have made all of the adaptors and have installed the 400-R on my HOT-HOT 308 eng. and will have the pics.ready to post by this week-end. ( your kit may be a better one than mine or LESS expensive ) ( my ride is also a 51 Brougham )
Hudsonly to all. Rudy.
In the process of installing a Turbocharger to the 2-barrel and will install the T.B.I. on the commpressor side.0 -
Greetings from Colorado!
Do you have any information on the G.M. T.B.I. setup that you are putting together? I have been thinking along the same lines and would appreciate any info that you have compiled! I have current thread running at http://www.classiccar.com/forums/showthread.php?t=3618
Thanks!
George T.0 -
Clifford also sell a T.B.I kit for their manifolds if you follow the link to their site they list the kit. A bit pricey though at around 2K.0
I haven't heard of modifying Chev HEI distributor for use in the 308, but would be interested in hearing about it. There have been posts in the past about adapting a Chrysler electronic ignition (from the late 70's, I think) to the Hudson- required just a slight amount of machine work on the shaft, otherwise said to fit and work perfectly. Wish I had more info, but maybe that can get you started Googling.0
- 111 Hudson 1916 - 1929
