replacement gas tank for PU
ive been searching for a replacement gas tank for my 46 hudson pick up the only part worth salvaging on the old one was the filler neck so ive been looking at tanks online and it seems the one for early 70`s el-camino looks close within an inch or two of size for the truck but i would like to get a little closer on the match does anyone know of a better match or are any of you parts dealers interested in having some reproduced what are the rest of you guys doing that need a gas tank ? - goo
What are the measurements and filler location on the EL Camino gas tank?0
I put an mid 80's Camaro tank in Trk. I used the Camaro straps too then redrilled the attachment holes. It fit up in between there so nicely I mounted the spare tire underneath.
Recalling back, I probably could have cut the pipe and adapted it using a hose thru the fender but my bodyman had already patched my fender fill hole so I elected to terminate flush in the bed floor.0 -
The boat parts people carry quite a good line of non-metal boat tanks.0
hope this link works the elcamino yank is close but not quite if i get desperate ill try it
http://www.carpartsdiscount.com/auto/parts/72/chevrolet/el_camino/gas_tanks/gas_tank_eec.html?3593=3995
goo0
- 612 Vehicles
