1932 Terraplane Conv..
Or you can take a shortcut to www.hetclub.org/burr and you'll find an index of the stuff I have in a Hudson on-line library. Scroll down to the bottom and click on a file called "Manuals", then scroll down to 1929 and you'll find Dave's 1929 Dover owners manual.
In the main index there is also a 1929 Dover Mechanical Specs file with info. It can be compared with the 1929 Essex - that Mechanical Specs file follows the Dover file. Also there is an August 1929 file giving the paint colors used on Hudson, Essex and Dover - that file is 1929 August Hudson-Essex Paint Specifications. (HINT: Hold your mouse pointer over the file name and the full name appears at the bottom of your screen).
This index will shortly be a web site, but for the moment things may be downloaded from the Index file.
Alex Burr
Memphis, TN
hetclub.org/burr0
