Power Steering set up for sale
harry54 wrote:
With out the crank and water pump double pulleys and a 54 water pump for this set up you are in trouble. Locate these items first unless you intend to buy and then resell. Figure on spending $500.00 or more to rebuild pump and ram cylinder. Walt.0 -
can this be adapted to a 53 hornet ?0
harry54 wrote:
Yes. but you need the 54 water pump, the double water pump pulley and the double crankshaft balancer. Walt.can this be adapted to a 53 hornet ?0 -
harry54 wrote:can this be adapted to a 53 hornet ?
Yes, you may have to do a little fabrication to mount the steering stops, otherwise you are good to go. Soon I expect to have a pump.original hoses,mounting bracket, harmonic balancer and waterpump pully on eBay. I need to pressure test the pump.. Will post as soon as I get time to do the work.;)
Lares Corp remanufactures your old cylinders with new piston. It's absolutely NEW...Phone number is 1-800-334-5749.
Hudson308 wrote:
The double pulley is longer so the shaft has to extend further out. Walt.What's different about the water pump, guys?0 -
Hudson308 wrote:What's different about the water pump, guys?
The fan mounting flange is pressed on just a little bit forward of the original position, I don't recall the difference at the moment. I think a few washers under the pulley would suffice. Dave Kostansik can sell you one that is correct. I have an old original one that actually has a longer shaft, but I really don't think that is necessary.;)0 -
SuperDave wrote:The fan mounting flange is pressed on just a little bit forward of the original position, I don't recall the difference at the moment. I think a few washers under the pulley would suffice. Dave Kostansik can sell you one that is correct. I have an old original one that actually has a longer shaft, but I really don't think that is necessary.;)
54 thru 56 engines had the longer water pump. There are plenty out there
Russ J0 -
Hudson308 wrote:
Only those with power steering. Walt.Russ;
Did all '54 engines have the longer water pump?0
- 612 Vehicles
