Needed: '37 Terraplane wiring diagram
Hudsonrules
:eek: This '37 Terraplane needs help with the wiring, primarily the head lights. I need a wiring diagram for the car with the correct gauge that was used when the car was new. Any Ideas or help would be appreciated. Thanks, Arnie in Nevada.
You'll find an electrical diagram in the Mechanical Procedures Manual which Alex Burr so kindly scanned and uploaded to the Net, http://www.hudsonterraplane.com/tech/MechProcMan/MechanicalProcedures.htm . However, I doubt that any such diagram is going to give you the correct gauge for the wires. Perhaps someone can step in here, and offer that advice.0
Jon correctly points you to Alex Burrs posts... within those posts is the owners manual and it contains a wiring diagram on page 50 in section 2 of the manual....
http://www.hudsonterraplane.com/tech/OwnerMan37/Terraplane37OwnersManualPart2.htm0 -
Not to nit-pick - the manuals are on-line and available. But to give credit where it is due, those two I didn't scan - Gregg did those.
Alex Burr
Memphis, TN0 -
Thanks for clarifying that! Credit should go where it's due!0
