Source for Terraplane parts.
[Deleted User]
So does anybody know of a source for weatherstripping parts (door and window) for my 36 coupe? Also would like to find some original type wiring harness.
No one answers the phone at Kgap. Thanks in advance...slim
  • I got my rubber from K-GAP some time ago.
    If you want to make your own harness, which I would suggest using heavier wire,
    you can get good original looking wire from Rhode Island Wire. I would also
    reccomend running a separate ground wire from the headlight connector all the way down to the frame. Depending on the overall diameter of the wire bundle
    from the headlight you may have to bore out the hole in the mounting bolt. I did
    this on mine and Ihave bright 6 volt lights even using the 50 CP bulbs.
    Howard
  • tigermoth
    tigermoth Expert Adviser
    hello, if you are looking for recommendations based on personal experience i can only offer restoration specialties and supply for window channel. for wiring i have heard good things about rhode island wiring and also ynz yesterdays parts. they both list hudson/terraplane among the cars for which they have patterns. narragansett reproductions also shows hudson patterns available. good luck. regards, tom
  • Ol racer
    Ol racer Senior Contributor
    All your Terraplane window Channeling can be obtained from Vic Zamora in Ca @ 562 947 5864.. Great Service, good Product & quick shipping.
