LED bulbs
Richie
Richie Senior Contributor
Has anyone used the 6 volt LED bulbs. I have heard they are much brighter than the standard OEM. It is hard to see the brake lights in the day light if the sun is behind the car. I have followed several cars with the standard bulbs going to car shows and it is hard to see when the brake lights come on.
Just wondering what your experiences are with LED bulbs. Thanks, Richie.
  • tigermoth
    tigermoth Expert Adviser
    i got mine from www.highspeedmotors.com george is a good guy. they are pretty bright. they are over voltage sensitive...don't ask me how i know.... bright with correct voltage too. regards, tom
  • Richie
    Thanks Tom, they are a little more expensive from what I've seen on the internet. About $9.00 to $20.00, but supposed to last a very long time. Richie.
  • Roger Harmon
    Roger Harmon Expert Adviser
    I've heard that LED's are more directional -that is the light they emit is more like a flashlight beam. Has anyone noticed that effect?
    R/ Roger.
  • SuperDave
    SuperDave Senior Contributor
    I use the 12 volt LED versions on my 49 commodore tail lights.One 1157 bulb for the standard tail and brake/turn signals and one LED just for the turn and brake. So when my brake lights are on or my turn signals I have two lights back there.THEY ARE BRIGHT. the standard filament and a LED. Thats why I switched from the Super tail lights that didn't have enough room for two bulbs. The standard turn signal flasher will not work with an LED bulb because it doesn't draw enough current. The 1157 bulb takes care of that problem.
  • hudsonguy
    hudsonguy Senior Contributor
    Super,
    Do you just tap off the 1157 bulb to power the LED's next to it?
  • SuperDave
    hudsonguy wrote:
    Super,
    Yep, That's what i did. :)
  • hudsonguy
    SuperDave,
    That was genius! Absolute genius! (seriously)
  • Geoff
    Geoff Senior Contributor
    Slightly off-topic, but I use these super-bright LED's in my Camper trailer, which I tow with either my modern 12v negative ground car, or my 6 volt positive ground Jet. I simply solder the LED's across the 12v bulbs, with the anode to ground. When the Jet is used, the 12 volt bulbs only glow very dimly, but the LED'S light up real good, and of course they don't come on when the negatvie ground 12 volt is hooked up, and the normal 12 volts bulbs do their job.
    Geoff..
  • SuperDave
    Geoff..
    Now THAT IS genius!:o
