Need: Door lock spring
Only one door locks on the handle, the front passenger door. What lock springs are you referring to?? I may be able to help.0
Its the spring that holds the handle in position when you push them forward to lock the door. (the inside handle)
Jeff0 -
OK Jeff, I will look around and see if I have any of these, I don't think so.0
Thanks Richard!
Jeff0
