The 1930 Essex Coupe restoration thread
TwinH
A new thread to document the trials and tribulations of fixing up this coupe
that followed me home.http://classiccar.com/index.php?option=com_jfusion&Itemid=62&jfile=showthread.php&p=122002#post122002
Thanks guys! I'm going to start a new thread for wants/needs, info,
moral support,etc while I wade through restoration of this neat old
30 Essex coupe. All here can share the blame/credit for infecting me
with this Hudson bug. As a lifelong Chevy guy that hot rodded almost
everything I got my hands on,this is a pretty big step for me. I have
a fairly substantial mechanical background including an A&P ticket and
have been through splasher motors before.What I'm really lacking is
the Hudson specific knowledge that members of this community have
coming out their ears. I look forward to mining this knowledge to make
this coupe the best that it can be. Thanks for the help, Jeff Lynn
«1
  • First order of business on this project is to get some fire in the holes. Since
    the time I first looked at this and took delivery the previous owner removed
    the non stock(Tillotson JR5A) updraft carb and cut the intake elbow and
    rotated it 180* so he could use a downdraft carb. Now I am looking for an
    intake manifold elbow and either a stock Marvel V-10-780 or any ideas for
    a stock appearing replacement. In the meantime I'll busy myself with
    compression and leakdown tests to verify condition and check the ignition
    timing and chain backlash. Thanks for any tips or leads. Jeff Lynn
  • Looks like you have a deluxe coupe, a very good score,
    and very complete
    I will have to sell you a mascot to go on her
    Mike
  • Mike,this mascot you speak of,got any pics?
  • Well I'm a month into this now and starting to get situated. I've found
    that the engine in it is a 29 model and I purchased a 31 motor/trans
    last week with a good carb/intake. My brother picked up the 31 and pulled
    the carb,intake,accessory drive housing,and exhaust manifold and shipped
    down here leaving the rest in Ohio. I knew the exhaust manifold was
    different(clamp-on 29-vs.-bolt on 31) but thought maybe the rest would
    swap. WRONG, the intake elbow on the 31 has a wider bolt pattern where
    it bolts to the block and a much larger "D"shaped intake port. The 29
    intake elbow that the PO destroyed has a small round port as does the
    29 block:(. Also the accessory drive housings are different as are the oil pumps,
    although the 31 came with the correct dizzy(the 29 had a Chrysler-Autolite
    dizzy that was functional)
    The intake mismatch throws a wrench in my plans for trying to get the 29
    engine running,unless I can find a 29 intake elbow to continue. I did take
    the advice given here and dropped the pan to find all kinds of sludge
    hiding there. The cylinder bores look decent from the bottom but the rings
    must be stuck in the pistons. Cranking compression averages about 50 psi
    dry and 70-80 with squirting oil in the cyls. Leakdown showed an average
    20/80 with no leakage past valves. All of it going past rings.Oiling the cylinders showed no or very low leakdown for the first couple seconds
    till the air blew all the oil past the rings then they went back down to
    around 20/80.
    The carb that came with the 31 engine looks great! All linkages on the
    carb and heat control are free and no sign of pot metal deterioration.
    Has a clear handmade lexan cover on the float bowl that is kind of
    strange but very well done.
    I haven't pulled any rod caps off the 29 engine in the car but although
    they seem decent on the rod journals at least 2 of the have .040"or
    more side clearance,so it seems I have issues there too. The light springs
    inside the oil pump on the 29 were corroded into pieces which is really
    no surprise after seeing the condition of the oil and the fact that they
    are such small diameter wire. I can likely come up with something to work,
    but holler if you know any sources.
    All thoughts or opinions are welcome.
    Sludge in the pan...
    Heat control/carb off 31 engine after a little cleaning...
    31 carb Anybody know how to determine what model of Marvel carb this is?
  • Continued...
    Here's why I can't swap the 31 heat control/intake elbow onto the 29 block
    Here's the accessory drive housing off the 29 engine. You can see whats
    left of the oil pump small springs just above the housing. What do you
    splasher guys do for oil pump parts??
    Here's the housing off the 31 engine that I haven't got into yet. The
    housing and oil pump are different from the 29. Also dizzy retention
    is different. I don't know how this is going to shake out yet.
  • I can probably help with oil pump spring if you can't find one closer than New Zealand!
    Like this 1 its a 30-31 Essex _Hudson, the Hudson 1 is slightly longer but most people dont know the difference
    Mike
  • TwinH,
    An interesting thread for sure. I enjoy seeing this kind of stuff.
    I'm not all that up on these early Essex cars but hope to learn some things.
    1) Are the 29 / 30 / and 31 engine all that different from one another that you can't swap many things?
    2) What the heck is a "Dizzy" ????????
    Keep up the good work and educating some of us.
    Ron
  • Here's some info that I hope helps with the Marvel carb:
    1929 Essex: Carb Assy. #10-733 Bowl Assy #: 65-588
    1930 Essex: Carb Assy. #10-780 Bowl Assy #: 65-618
    1931 Essex: Carb Assy. #10-946 Bowl Assy #: 65-631
    From my 1925-1933 Marvel Chart.
    Rick
  • Oldcar_Mechanic wrote:
    TwinH,
    Ron
    The dizzy is the distributor
    Mike
    Mike
  • 30 Essex in OZ doesn't have a mascot & I don't think U.S. models had one either.
    new oil pump springs are available in OZ. e.mail Phil Haxby hetrules@yahoo.com.au or pphilha@tpg.com.au He is away till 15 th May but may be worth a try.They cost $10 AUS. plus shipping.
    I have an inlet manifold available you can have for the cost of shipping but I think you should be able to get one closer to home,let me know if you need it.
  • I have a spare elbow for the '29 Essex.
    David Weinstein
    erbpartners@gmail.com
    David Weinstein
    I really appreciate the offer David. I got a 29 elbow and the 31 carb won't
    bolt to it... Just got back from Ohio where I strapped the 31 engine/trans
    on a pallet and sent it down here. Thinking now I'll be using this 31 engine
    instead of the 29. It is supposed to be here tomorrow,so we'll soon see
    how this works out.
  • Engine got here fine and on time. Turns out it is a 1930 and not a 31 as
    advertised.Perfect for the 30 coupe though. Broke it down and got it on
    an engine stand yesterday. You may recall I bought the 30 coupe with a
    29 motor in it sans carburetor and then found issues with the oil pump,
    connecting rods,stuck rings and the fact that the intake elbow from the
    1930 won't swap to the 29.
    The 30 engine seems in better shape EXCEPT for a lot of pitting on the
    rearmost (exh) lobe on the camshaft. Weird as all the other lobes look
    just fine and the affected lobe is OK on the base circle but horribly pitted
    on the opening and closing ramp.:( More fun in store I'm sure as I get farther
    into it.
    Engine arrives,
    Teardown, note that the transmission tried to go all "Deepwater Horizon"
    on me...
    Abundance of mice/squirrel food in the water jackets...
    cont...
  • Finally,on the stand...
    Stay tuned! Jeff Lynn
  • Thanks for the update. I'm following this closely.
  • Hey TwinH, does that engine bolt up to a normal engine stand?
  • Good question Steve. The answer is yes, but not without a lot of head scratching. I'll try and post up a pic tonight. Jeff
  • Thanks Jeff.
  • Here you go Steve,pretty tight around the crankshaft flange but it does fit
    OK. Question,does the gray/green color in this pic look like the original color?
    Getting ahead of myself,but who sells engine paint for Essex engines? Is it
    the same as Hudson? I just haven't looked around yet,but figure there will
    be knowledge here.
    Off with the head! Had this actually ran I'm guessing it would have been on
    the warm side. Who knows how much ditch water has gone through here
    over the years. See that third water port?
    Its a golf tee...
    This extra hardware came out of the hose end of the water manifold.
    cont...
  • Thanks Jeff. That's an amazing amount of stuff in the water passages. How the heck did a golf tee get in there I wonder? Who knows after 80 years.
  • The cylinder head nuts all came off quite easily with the impact gun and the
    air turned down to 40psi. Wish I could say the same for the studs but I'm
    sure I'll spend much more time on them. I've had luck before heating up the
    cast and using candle wax to wick down into the threads. What is everybody
    else's preferred method for removing studs that go into a water jacket?
    All is going well,no ridge in the cylinders to speak off,THEN, I see this in the
    #1 cylinder on the valve side... aargh,what the heck? Don't know what
    caused this yet but would be interested in opinions. I'll pop the piston out
    tomorrow and share the results. Interestingly there are no marks, grooves
    etc below this. Hhhmmm.
  • Twin-H
    If you are going to reuse the old pistons get them x-rayed for cracks,I did and all of them had cracks around the gudgon pin and most had cracks in the top above the ring.The photo's attached show the gudgon cracks but I don't have photo's of the top.These cracks are not visable to the naked eye.
    Spencer.
  • Lester Harris of Minden Nevada has NOS pistons for the Essex - cast iron not ali. He's in the roster. Good prices & a helpful guy.
  • Pistons from a Caterpillar Pilot engine are the same size and are alli. They go straight in but only have 2 compression rings and 1 oil ring above the gudgon. I have had these pistons in my car for about 8 years without any problems.The price here in AUS. was cheaper than new Essex pistons. The advantage with these pistons is there is a lot more distance from the top of the top ring to the top of the piston, if you put the two side by side you will see the advantage.
    Spencer.
  • Don't use cast iron p0istons, they make the engine sluggish and harsh because of the extra weight, as they up set the orginal balancing.
  • Spencer Yarrow wrote:
    Twin-H
    Spencer.
    Gee Spencer,your just full of good news. I have only looked the #1 piston
    over well and can almost see at least one of the cracks you speak of. I'll dig out
    some old dye penetrant inspection spray bombs that I haven't seen in 20 yrs.
    and see if they will show the cracks. I will definitely check into the Caterpillar
    "pony motor" pistons too that sounds like a great alternative. I really wouldn't
    be interested in iron pistons but I still appreciate the tip. I think you'd have a
    hard time balancing a much heavier piston with the crankshaft.
    No pics yet but the crank and rod/pistons are out and #1 piston shows no
    damage that could cause the Oklahoma shaped gouge in the #1 cylinder
    wall. I'm really starting to believe that the gouge may be a boring bar
    accident from when this engine was built 80 yrs. ago. If thats the case
    its hard to believe the rings are still in one piece and harder to believe
    that they would have actually sent it on down the line knowing that it
    had such an obvious defect.:confused:
    Thanks to all for helping bring this 80 year old piece back to life. Jeff Lynn
  • put that motor and head into a molasses bath, will come out looking like new.
    55 gallon drum, 5 gallons of molasses from a feed store & water. let the motor soak for about 2 week. rinse and coat the motor so it doesn't flash rust.
    this will work on any cast parts you want to clean.
    KH
  • I'd love it to be much cleaner already and have heard of the mollasses bath
    but I'd be afraid of ruining the Babbitt on the mains.
  • Anybody have a special recipe or procedure for degreasing the block
    without destroying the babbit?
    The 29 engine/trans came out last weekend.
