NOS Hudson Fog lamps In Box Forsale
Unknown
I just listed a perfect set of NOS Hudson Foglights on e-bay. May trade towards a Twin-H unit or ?... Thanks, Niels
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=300417514841&ssPageName=ADME:L:LCA:MOTORS:1123
  • RL Chilton
    Niels-
    Will trade for Twin-H stuff? I'm sure I have what you need. Send me an e-mail. I'm up for a trade. Since these are original Hudson equipment, I'm interested.
  • 53jetman
    53jetman Senior Contributor
    Russell - I'd double check to make sure you have sufficient open space on the front fender below the headlight to use thiese fog lights. These were brought out at the time of the 1948 anouncement, and if my memory serves would fit up thru 1950 models. With the advent of the wider grill on the '51 thru '54, I question if you would be able to mount these units.
    Jerry
    ]53jetman
    Jerry
    ]53jetman
    Yup, I went out to my 52 and I think you are right. Looks like 48 to 50 unless you want to fabricate a bracket.
  • RL Chilton
    Jerry-
    Thanks for the heads-up, and thanks Niels for checking. Fortunately, I have an older after-market Unity copy pair similar to ones Niels posted. They have the mounting bracket that has a 'C'-bend in them and will work on my '52. Still interested.
    Niels-
    Sent you an e-mail. Will get back to you tomorrow.
  • Richard E.
    Richard E. Senior Contributor
    Where on the front end do these mount on a '50?
  • RL Chilton
    Typically on the front valence (panel behind front bumper).
  • The following pictures show ... thru fender fog lights 48, 49, 50 and the later fog light location which is mounted on lower grill valence...
