55 overdrive tranny
ski4life65
I am using a 55 308 in my 52 Hollywood. Does the 3 speed overdrive that was originally attached to the 55 have any value, or is it just a big anchor?. Will it work on a Nash or V8 Hudson?
Don
Don
Hi,
Would that be a manual 3 speed OD?
Sure would love to put one in my 36! An overdrive would be very nice but dont know if it would work.
Thanks,
Jeff0 -
It is, but it is set up for a torque tube, not a standard drive shaft. I have been told it is too much trouble to covert, or I would be using it.0
I would like to have it i have a over drive 57 i could use it in if it's a good trans it will not fit in a step/down and it is a dubble leaver just were are you at ?? And how much for the trans ?0
Paul,
Are you saying this will fit a V8? I believe it is a good trans. The car was on the road until it blew a head gasket. I pulled the motor to use in my 52. Put a new gasket on, and fired it up. I am currently swapping out the motor mounts and oil pan. Still looking for a decent trans to mount back on.
Don0 -
Oh well.......
Was a nice idea.0
