our 29
Is that a water pump, starter and generator all in one line?0
no .the starter is not connected to the gen:)0
Because the shaft runs through the water pump, is steel, and gets wet, it tends to rust. And the resulting "pock marks" in the shaft -- located right at the water seal -- then make it hard to seal. So, you always have a slight drip-drip-drip around the water pump (which is no big deal, actually). A fellow I know, actually went to the trouble of having a stainless steel shaft made, so it wouldn't rust. I wonder if Jack Smith (who owned your car) went the same route?
I also note that your car has a right taillight, which was (I believe) not standard -- at least in the States. I know people who have fabricated the brackets and put them on, themselves. Here again, I suspect Jack may have done this. Or, possibly if this is a Canadian-built Hudson, that may have been standard or an option in 1929, unlike the States.0 -
The reason that the generator and the starter are aligned is that when the engine first came out, they used a starter/generator. There was a clutch on the generator end that disengaged when the starter was being turned over and then engaged once the engine was powering the shaft.0
So does that engine block date back to 1916, when the first Super Six came out?0
akcoop wrote:The reason that the generator and the starter are aligned is that when the engine first came out, they used a starter/generator. There was a clutch on the generator end that disengaged when the starter was being turned over and then engaged once the engine was powering the shaft.
Hudson used the starter/generator units from 1913 (first year I've been able to document) thru 1922. Essex hit the ground running with a starter and generator.
Alex Burr
Memphis, TN
http://hetclub.org/burr0 -
Does anyone notice that the tapit gallery covers have been custom made. theres no firing order or hudson logo, and no rivets showing. The factory covers leak oil bad when the gasket gets old. Jack or someone got tired of always cleanig up the oil stains.0
Very eagle-eyed of you! What a good fix for this problem. How come I never thought of this?0
Jon B wrote:So does that engine block date back to 1916, when the first Super Six came out?0
- 173 The Flathead Forum
- 599 Vehicles
