308 distributor
I'm hoping someone can tell me the difference. I have a IAT-4009B distributor for my 308 whch is a 53-54 Hornet. It is a little loose and I'm thinking of getting it rebuilt. I recieved another distributor in the mail today that I purchased on e-bay that is an IAT-4009 (51-52 Pacemaker or 53-54 Wasp) that is very tight. Can anyone tell me the difference in these two units? The shaft length is the same and outwardly they look alike.
Thanks
Jeff
Kelseyville, Ca
Thanks
Jeff
Kelseyville, Ca
Jeff,
I believe that the difference is the springs and weights for advance.
Larry0 -
Ducor Kid wrote:Jeff,
Larry
That's what I was told, as well, Jeff.0 -
Thanks for the answer. Sounds reasonable. Do you guys know a good rebuilder for the distributor and where I might get a correct functioning vacumn advance. Is there a way to test a vacumn advance at home??? Could I possibly change the spring a weight assembly from my hornet to the pacemaker distributor?? Technical questions but fun to work on.0
Randy Maas rebuilds them and could rebuild it any way you like.0
Even possible to change it to electronic ignition, if you so desire.0
- 115 Hudson 1916 - 1929
