rebore on a 36 terraplane block
Splasher sixes shouldn't be overbored more than .030, otherwise they run hot.0
So, can they be sleeved if more than .30 over would be necessary?0
denverslim wrote:
They can be resleeved but you may have trouble when you torque the head. A good machine shop should be able to clean it up at 0.030 with a honing machine. 30 is the safe size. Walt.So, can they be sleeved if more than .30 over would be necessary?
.0 -
Not to argue with the experts , I would never go more than I had to , but My 37 is .040 over and no heat problems at all . Gets pretty thin sealing the head gasket between cylinders but it is holding . BUD0
walt's garage-53 wrote:
Interesting,what causes trouble when you torque a resleeved head?They can be resleeved but you may have trouble when you torque the head. A good machine shop should be able to clean it up at 0.030 with a honing machine. 30 is the safe size. Walt.
.0
