50 Hood release
Not original I know but I got a cable, and handle, from Auto Zone. Cable feeds through the original cable housing.
Bob0 -
Same thing happened to mine, put JB weld into handle, reattached on cable, and now works fine.0
Per Bill Albrights sage advice, I put an external release on my 49 Super, in addition to the internal factory cable. I just used a spare piece of 3/16 brake line, using the flare on one end to capture it in a hole drilled into the release lever. It then extends toward the driver's side headlight, and is held up at the this end by an eyebolt. A piece of vacuum hose around it to eliminate vibrations, and it works great. It cost virtually nothing, and I find I use it more than the internal release.
Doug0
- 104 Hudson 1916 - 1929
- 173 The Flathead Forum
- 599 Vehicles
