remove brake drums??
You need a hub puller. See this post for details. This is for later brakes, but should show you what is needed.
http://hudsonpix.multiply.com/photos/album/52/REAR_WHEEL_PULLER0 -
HI I POSTED THIS A FEW YEARS AGO I HOPE IT HELPS YOU WILL NEED THIS TYPE OF PULLER
FOR YOUR CAR I WOULD SAY CONTACT CARL WEBER FROM MAS. YOU NEED A HUB PULLER IT'S ALOT DIFFERENT THAN THE ONE I POSTED ABOUT GOOD LUCK 0 -
The type of puller you need is a large steel hub which screws on to the hub-cap thread, with a large bolt through the centre which bears against the end of the axle and pops it off the taper. If the car is mobile, loosen off the axle nut and drive it round the block a few times and it will usually come off .0
- 115 Hudson 1916 - 1929
