1954 with 254 8-cyl motor?
Unknown
Anyone know if some one has ever tried this ? I realise they never came that way but were there things changed that would make it hard to do? I allway's liked the way that motor ran. And I have a 54 that needs a motor- so - I just been thinking.
I have an eight that could be fixed and put in it ?
Roger
  • bob ward
    bob ward Senior Contributor
    The underpinnings of a 54 are the same as earlier stepdowns, so fitting an 8 should present no problems.
  • Geoff
    Geoff Senior Contributor
    Basically all you would have to do would extend is the exhaust pipe to the front of the motor. Otherwise everything else should fit right there. It must be a Step-down 8 though, as it has a special sump to fit over the suspension.
  • Uncle Josh
    Uncle Josh Senior Contributor
    You'll have to rotate the radiator brackets 180 deg to move it 2 inches forward as the 254 block is exactly that much longer than the 6
  • Park_W
    Park_W Senior Contributor
    To move the radiator forward you may have to do some cutting on the filler panel between radiator and grille top. The earlier stepdowns had two different filler panels ... one for the sixes, one for the eights.
