Hot Rod for sale
essexcoupe3131
Well here is someone selling a 31 Essex greater 8, I have had a good look at it and recon that its a 28 Essex and if so cant even be a greater 8 as they weren't around then
I tried to email the at there question area but wont let you do anything
the front suspension looks pretty cool as does the rest
Even the ID tag I think is not what they were issued with :ohmy:
http://cgi.ebay.com/ebaymotors/Other-Makes-Hudson-Essex-Greater-Eight-2-Door-Coupe-Hot-Rod-Hudson-Essex-Greater-Eight-2-Door-Coupe-/260679955336?pt=US_Cars_Trucks&hash=item3cb1bc7388
thoughts
Mike
thoughts
Mike
Since they have a Chevy 350 in it--they have also decided to use the same creativity to sell the car. I often wonder, if you are going with a 350 crate engine why not step up and do the R-4 tranny? You would have much better performance and economy...0
Hi brownie, I wished I had put a 400r in but now looking at some stage to put a over drive on the turbo,
I good suspect for false advertising, someone may buy it and then sue later who knows, as a take it as as I see it a lot of that goes on in the states
Mike0 -
I chuckle some times when I read the add's. Between the "Rare's and Original Reatorations" and the comments about how easy it would be to restore the car I find a lot of humor in the For Sale adds.
By the way, I am working on a 39 Custom Hudson Roadster and I made the decision recently that I would go with a 5 speed standard transmission rather than an automatic. I was going to do the 700 R4 tranny and then just decided that since it is a rebuild of an original early 50"s hot rod that it would do better with the 5 speed on the floor. It will bolt up to a early Corvette 327 with 3 X 2's. (the last engine that it had in it when it was running was a 1955 Chevy 265.)0 -
Hi Brownie, that was the combo I had for the coupe originally, I had a virgin 327 block too, it ended being put into a jet sprint boat down here
I still kick myself for not using the block and manifold
though I was still using a turbo 350 then, when I started building this, we had so much regulation parts were so hard to come by unless you were wealthly
Not like up there you just go to a wreckers and choose we mostly had 4 and 6 cylinder cars
Mike
Mike0
- 109 Hudson 1916 - 1929
- 176 The Flathead Forum
- 605 Vehicles
