choke/manifold heat tubes
RonS
RonS Senior Contributor
What do you guys like to use for the insulation on the copper tubes going from the exhaust manifold to the carb choke spring( two on the twin H).Fuel line insulation diameter is a bit to wide. What looks authentic and where to buy it?
  • onerare39
    edited December 2010
    Here's what I used. The only thing different from the original is that the ends of the insulation are covered with a black coating to keep from fraying, and Hudson used a hog ring to hold the insulation onto the choke tube which limited the fraying. They come in a standard length of which one is a 1/2" too short for the front choke tube on Twin H. I just put the short side up at the carb and you cant see it because of the air cleaner.
    http://www.lategreatchevy.com/chevy-choke-heat-riser-tube-insulation-1958-1964.html
    Hope that helps!
    John Forkner
  • RonS
    Thanks John. Mine are original and they are getting brittle. I did the same with the ends by the carbs, but now they are about a inch short. I ordered a pair from Ecklers.
