12 volt bulb number needed
Chris Smith
Chris Smith Expert Adviser
I am assembling the steering column on my 54 Hornet after rechroming. I need the 12 volt bulb number to replace the FS51 6 volt bulb that lights up the hydramatic shift selector pointer.
thanks
Chris
  • Chris,
    When I converted my 54 Hornet to 12 V last summer I used #57 lamps for the Hydramatic shift selector and all dash lights, including the oil and gen lights.
    Hope this helps,
    Tom
  • Chris Smith
    That helps, thanks. I also wonder if anyone is reproducing the steering column seals at the floor pan. One is a molded rubber and the other is just a flat piece that is fabric reinforced rubber.
  • Marconi
    Marconi Senior Contributor
    Hey Chris, 12 volt bulbs to replace 6 volt ones are as follows; 53 for51, 57 for 55, and 67 for 63. Give me a call if you need other ones. Steve.
  • Chris Smith
    thanks Steve
  • Walt-LA
    Walt-LA Senior Contributor
    12 Volt Bulbs (1951 Hornet)
    Not sure all are used in the '54s. Walt-LA
    use number bulb designation
    Courtesy lamps (doors) 4 1073
    Tail/brake 2 2057
    Park/turn (front) 2 2057
    Turn (rear) 2 1056
    Tag 2 67
    Grille (emblem) 1 57
    Dome 1 1073
    Dash lights 3 57
    Gen/Oil lights 2 57
    High beam 1 57
    Radio 2 1893
    Hydromatic (NDLR) 1 53
    Quarter lights 2 89
    Flasher 1 NAPA 7319
    Headlights 2 -
    Trunk 1 1073
