37 Hudson eletric hand transmission an other parts
I would like to know if there is any one out there that is interested in a 1937 eletric hand transmission I also have the steering column tube with the eletric hand shift on it for a 1937 plus a 1936 steering column with the steering box and eletric hand shift on it I am not going to use these and would like to sell if any one can use them.
Yes, I sent you a message.0
I too have sent a private message!0
Hi,
Curious if the 37 parts will fit on a 36T?
Thanks,
Jeff0 -
Jeff, believe it or not, there was an early and a late Electric Hand. The change was made in mid 1936, so yes the Electric Hand parts will work on the '36T. The steering column probably would not, but the tranmission is the same as '36. However, I believe that the above mentioned parts have been sold - to me!0
