'54 Hudson Sedan, Car show in Vista Ca.
:ohmy: Click on first pic and it will go to the next pic.
:cheer: http://public.fotki.com/wackydave/car_shows/car-shows-2011/24th-annual-vista-b/010811-vista-burger-260.html
http://public.fotki.com/wackydave/car_shows/car-shows-2011/24th-annual-vista-b/010811-vista-burger-265.html#media
Two Battiers?:ohmy:
http://public.fotki.com/wackydave/car_shows/car-shows-2011/24th-annual-vista-b/010811-vista-burger-270.html#media
Two Battiers?:ohmy:
Did you notice it has two batterys?0
Looks to be 6V and 12V Optimas. Thats one way to do it I suppose. Gotta give everything the same ground though.0
:ohmy: Is that a glass brake fluid container on the firewall?:S
http://public.fotki.com/wackydave/car_shows/car-shows-2011/24th-annual-vista-b/010811-vista-burger-270.html#media0 -
VicTor Z wrote::ohmy: Is that a glass brake fluid container on the firewall?:S
I was wondering that too. Could it be a Marvel Mysyery Oil injector? Also noticed it had an aftermarket vacuum canister, but no power brakes... great idea when it's raining!
John0 -
Vic... Yes that is an aftermarket brake fluid container. The fluid is fed to the under floor master cylinder via a hose connected to a replacement lid that was part of this accessory.0
I would say, 6 volts to run car and 12 volts for starter. Walt.0
Anyone out there see any 8 volt battery's out there? Can you find a battery charger for them?0
Don't know if they are still out there or not. I had one in my 1941 Chris Craft years ago, I used a 6 volt battery charger on it.0
Last time I was at the Farm & Home they had 8 -volt tractor batteries. Ant as far as charging them an old fashioned 6 -volt charger should . A modern electronic one probably would not know what to do. I have an old gas station gharger (Phillips 66) and it has setings for 12 or 6-8 volt,
Roger0
