engine dimensions
mrsbojigger
Hi Richs,
Maybe this will help. This chart will also help others with different engines.
Chaz
http://www.carnut.com/specs/engdim.html
Chaz
Chaz, do you know if they show and dimensions for the later model engines (i.e. LT1, LS1, Hemi 5.7, etc.)?
Jay0 -
Hi Jay,
Here are two places to find the dimensions.
hotrodlane article says that the LT1 is the same as the early blocks. Check it out. Paceparts is for LS1 dimensions.
http://www.hotrodlane.cc/PDFFILES/real%20street%20camaro.pdf
http://www.paceparts.com/index.asp?PageAction=Custom&ID=586
Hope these all help. Maybe we should put these web addresses in our "favorites" lists or make copies for our records. I am going to earmark them for myself. BTW, I have an LS1 thats going in my stepdown.
Peace,
Chaz0 -
Another thing you can use, possibly rent, buy, or borrow is a dummy block or engine mock up.
They can be a little spendy (175+) to buy but are nice to have around and beat using an engine hoist over and over and over and ... well you get the picture!
I fit both my engine and trans at the same time so I did just that - put the motor/trans assembly in and took it out...and put the motor/trans assembly in and took it out... probably 20-30x to make sure everything was fitting correctly with the mods I had to make.
Like Chaz says "measure twice (or 20x
), cut once" that's priceless advice for fabrication no matter what it is!
*0
- 115 Hudson 1916 - 1929
