Hudson 308 Valves
Ken, good to see you in here. Stop by more often, your experience and advice is valuable.0
The only valves that will be closed is the cylinder that is about to fire. Firing order, 1-5-3-6-2-4
Turn engine clockwise slowly and watch the second valve from front, when you see it open and start to close, watch the first piston and when it reaches the top, you are on number one ready to fire. Both valves should be closed. Valve arrangement is as follow, int-intake-exh-exhaust
exh-int-exh-int-int exh-exh-int-int-exh-int-exh Walt.0
