what is this from?
I seen this pic of what looks to be a hudson 308 but when i looked at the motor mounts they
look different than the one's i have seen? whats this motor from? or do you think someone modified the original to put in something else?
thanks for your help
hash0
here is the rest of the picture.
As Nick said Hash or 1955/56 engine. If you look above vacuum advance line, you can see boss where serial number is stamped. Serial number starting with F1001 is 1955 and starting with F8601 is 1956.0
Looks like a 262 block from a Wasp to me.0
that is a 55 or 56 308 the water pump has longer shaft and oil pan is different from 51 to 540
- 105 Hudson 1916 - 1929
- 173 The Flathead Forum
- 599 Vehicles
